Wys³any: 2017-03-17, 12:39 Tony h. e46 330ci 2004r lift manual 6 biegów RL ;-)
Coupe e46 330ci. Skrzynia manual 6 biegów.
Przebieg 250 tys km. Książka serwisowa. Oryginalny M-Pakiet. Xenon itp....
Teraz jeszcze trzeba przełożyć
Type code BD52
Type 330CI (EUR)
E series E46 (2FL)
Series 3
Type COUPE
Steering RL
Doors 2
Engine M54
Displacement 3.00
Power 170
Drive HECK
Transmission MECH
Colour TITANSILBER METALLIC (354)
Upholstery STOFF LASER/ANTHRAZIT (G7AT)
Prod.date 2004-03-15
Vehicle options
S1CA Selection of COP relevant vehicles
S226 Sports suspension settings
S249 Multifunction f steering wheel
S251 Runflat indicator
S302 Alarm system
S313 Fold-in outside mirror
S338 M Sports package II
S428 Warning triangle and first aid kit
S431 Interior mirror with automatic-dip
S441 Smoker package
S459 Seat adjuster, electric, with memory
S474 Deleted, front armrest
S481 Sports seat
S495 3-point belt and headrest, center rear
S502 Headlight cleaning system
Vehicle options
S508 Park Distance Control (PDC)
S521 Rain sensor
S522 Xenon Light
S534 Automatic air conditioning
S650 CD player
S661 Radio BMW Business (C43)
S692 Preparation, BMW 6-CD changer I-bus
S710 M leather steering wheel
S716 Aerodynamics package
S760 High gloss shadow line
S772 Interior moldings Alu Black Cube
S775 Headlining anthracite
S785 White direction indicator lights
S787 BMW alloy wheel, M double spoke 135
L812 National version England / Ireland
Vehicle options
S850 Dummy-SALAPA
S863 Retailer Directory Europe
S877 Delete cross-pattern operation
S880 On-board vehicle literature English
S8SM Car ident. number visible from outside
S8SP Control unit CO2
Vehicle options
S210 Dynamic stability control
S520 Fog lights
S550 On-board computer
S832 Battery in luggage compartment
S853 Language version English
Jako ciekawostkę po numerze rejestracyjnym znalazłem w sieci takie coś:
Mileage Details
MOT Date Mileage +/- Difference
28/10/2016 166,549 Miles +19,185 Miles
28/10/2015 147,364 Miles +15,755 Miles
29/10/2014 131,609 Miles +13,890 Miles
26/10/2013 117,719 Miles +96 Miles
22/10/2013 117,623 Miles +10,326 Miles
22/10/2012 107,297 Miles +4,034 Miles
14/10/2011 103,263 Miles +8,671 Miles
15/10/2010 94,592 Miles +5,737 Miles
24/03/2010 88,855 Miles +500 Miles
05/03/2010 88,355 Miles +8,173 Miles
29/04/2009 80,182 Miles +11,578 Miles
08/01/2008 68,604 Miles +12,141 Miles
19/03/2007 56,463 Miles
Average Miles Per Year: 12,811
Highest Miles in a Year: 19,185
MOT History
Test date 28 October 2016 Expiry date 28 October 2017 Test Result Pass Odometer reading 166,549 miles MOT test number 2786 1381 0402 Advisory notice item(s)
Offside Front Shock absorber has a light misting of oil (2.7.3)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Both front tyres worn on shoulders
Test date 28 October 2015 Expiry date 28 October 2016 Test Result Pass Odometer reading 147,364 miles MOT test number 6520 3353 1712
Test date 29 October 2014 Expiry date 28 October 2015 Test Result Pass Odometer reading 131,609 miles MOT test number 2955 9290 4366 Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Test date 26 October 2013 Expiry date 25 October 2014 Test Result Pass Odometer reading 117,719 miles MOT test number 8971 9969 3225 Advisory notice item(s)
Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Nearside Rear Brake pad(s) wearing thin (3.5.1g)
Offside Rear Brake pad(s) wearing thin (3.5.1g)
Offside rear brake fluctuating, but not excessively (3.7.B.3)
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Under-trays fitted obscuring some underside components
Engine covers fitted obscuring some components in the engine bay
engine oil level low
Test date 22 October 2013 Test Result Fail Odometer reading 117,623 miles MOT test number 1375 4589 3205 Reason(s) for failure
Nearside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Nearside front brake fluctuating, but not excessively (3.7.B.3)
Offside front brake fluctuating, but not excessively (3.7.B.3)
Nearside Front Brake pad(s) wearing thin (3.5.1g)
Offside Front Brake pad(s) wearing thin (3.5.1g)
Test date 22 October 2012 Expiry date 21 October 2013 Test Result Pass Odometer reading 107,297 miles MOT test number 7055 5679 2215
Test date 14 October 2011 Expiry date 14 October 2012 Test Result Pass Odometer reading 103,263 miles MOT test number 7094 2768 1226
Test date 14 October 2011 Test Result Fail Odometer reading 103,263 miles MOT test number 4182 1778 1201 Reason(s) for failure
Nearside Headlamp aim too high (1.8)
Offside Headlamp aim too high (1.8)
Test date 15 October 2010 Expiry date 14 October 2011 Test Result Pass Odometer reading 94,592 miles MOT test number 3839 7888 0217 Advisory notice item(s)
Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Test date 24 March 2010 Expiry date 23 March 2011 Test Result Pass Odometer reading 88,855 miles MOT test number 8334 5368 0068
Test date 5 March 2010 Test Result Fail Odometer reading 88,355 miles MOT test number 6806 0406 0068 Reason(s) for failure
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Front Torque/reaction arm has a deteriorated rubber bush resulting in excessive movement (2.4.G.2)
Offside Front Torque/reaction arm has a deteriorated rubber bush resulting in excessive movement (2.4.G.2)
Test date 29 April 2009 Expiry date 28 April 2010 Test Result Pass Odometer reading 80,182 miles MOT test number 6507 2941 9111
Test date 8 January 2008 Expiry date 7 January 2009 Test Result Pass Odometer reading 68,604 miles MOT test number 7302 7850 8020
Test date 19 March 2007 Expiry date 31 March 2008 Test Result Pass Odometer reading 56,463 miles MOT test number 3313 5827 7007
....Kierownica jest po niewłaściwej stronie.... Podczas przekładki pokusiłbym się jeszcze o montaż navi.
Bardzo ładna sztuka. I te felgi.. Dare LM czy ogyginał ?
TONY H., .....nawet pomimo tego że beta uwalona po same lusterka, to zdjęcie ze Szkocji i tak miażdży...
Widzę że u Wrony niezmiennie ten sam poziom przekładańców... high
Bardzo ładnie wygląda.
Ps. masz jeszcze e90 ?
Ostatnio zmieniony przez Adam86 2017-06-01, 19:55, w ca³o¶ci zmieniany 1 raz
